Query to find orphan blocks?
Is it possible to have a query which will pick up blocks where the block (and any of its nested children) do not have any page / tag reference (in any direction)?
Motivation is that I (as many others) write in Journals window by default, and it’s easy for some notes to slip through the cracks. With this query, it would be easy to find them.
I’ve seen somebody suggested using something like #fleeting when working with such block (when you’re not sure where they’d go), but with such a query, one wouldn’t even need to remember to tag it :slight_smile:
Something like this:
 :in $ %
   [?block :block/page ?page]
   (not [?block :block/refs])
   (not
     (descendant ?d ?block)
     [?d :block/refs]
 :inputs [
       [descendant ?d ?b]
       [?d :block/parent ?b]
       [descendant ?d ?b]
       [?d :block/parent ?parent]
       (descendant ?parent ?b)
Thank you for replying! This is close to what I want - is it possible to NOT pick up blocks this picks up blocks e.g. this block talks about [[logseq]]?
Sorry, I don’t understand your question.
No problem, let me try to clear it up. Appreciate you sticking with me :slight_smile: The idea is that sometimes I make quick blocks in my daily journal and if I forget about them. And then it’s really difficult to find them, because they’re not connected to anything else in my graph.
So the query should pick up blocks like this
- single block
- or a block with children
  - as long as its children
  - do not have any page references
  - or tag references
  - or are not referenced by their ID anywhere?
id:: aaaaaaaa-aaaa-aaaa-aaaa-aaaaaaaaaaaa
- block with unused id
ideally, the query should return only top-level blocks, i.e. both single block and or block with childer but not as long as children to avoid duplicating the results
The query should NOT pick up any of these
- blocks referencing a [[page]]
- blocks that have a #tag
- blocks that have children
  - that either reference a [[page]]
  - blah
  - or reference a #tag
  - blah
If not to difficult, it would be good to exclude reference / embed by id. So these shouldn’t appear on the query as well
id:: bbbbbbbb-bbbb-bbbb-bbbb-bbbbbbbbbbbb
- this block is referenced (so should not be returned in query results)
id:: cccccccc-cccc-cccc-cccc-cccccccccccc
- this block is embedded (so should not be returned in query results)
- ((bbbbbbbb-bbbb-bbbb-bbbb-bbbbbbbbbbbb))
- {{embed ((cccccccc-cccc-cccc-cccc-cccccccccccc))}}
As I’ve been typing this, I’ve realised that the query should only search in Journals, as it’s only there the unfiltered notes will be.
Try this one:
 :in $ %
   [?page :page/journal? true]
   [?block :block/parent ?page]
   (not [?other :block/refs ?block])
   (not
     (or-join [?d]
       [?d :block/refs]
       [?p :block/refs ?d]
 :inputs [
       [descendant ?d ?b]
       [descendant ?d ?b]
That’s perfect, thank you so much!
This query is wonderful, thanks a lot! I have a question though. Is it possible to have this query not to render empty blocks?
At the end of :where add four lines like these:
   (not
     [?block :block/content ?content]
     [(= ?content "")]
 :inputs [
Worked like a charm. Thanks again, @mentaloid
Would it be possible for the query to show the results in ascending journal file name order? (YYYY_MM_DD) (oldest first).
Apparently, for now, it’s listing the pages in descending order (most recent first).
Thanks in advance!
If you search the forum, there are many results, usually this one:
:result-transform (fn [result] (sort-by (fn [r] (get-in r [:block/page :block/journal-day])) result ))
This has chronological order by :block/journal-day. If you prefer the name, replace it with :block/name.
Thanks for the insight, @mentaloid. I tried to do some searching but I’m not fluent in the query language yet. I could not get the results I expected.
BTW, I’m not exactly sure where to put the snippet you provide. Tried at the bottom and got something. Thanks again.
Just search for :block/page :block/journal-day and you’ll get many examples. It could go here:
Hi mentaloid,
Is it possible to eliminate queries from above orphan block query?
I’ve tried to add a clojure “start with” filter after or-join but it isn’t working as expected.
(not [(clojure.string/starts-with? ?content “#+BEGIN_QUERY”)]
Check your syntax and any error messages. This works to me:
(not [(clojure.string/starts-with? ?content "#+BEGIN_QUERY")])
Also have to consider hidden query properties.
So content may not start with #+BEGIN_QUERY.
Can use clojure.string/includes? instead if that is the case.
This is actually the problem often when starts-with doesn’t work. When referencing a block somewhere it gets a hidden id property, which also stops starts-with from working.
Thank you guys. I followed Siferiax’s advice to change clojure.string/start-with? with includes and am now able to exclude hidden queries from orphan blocks. Cheers! :bubble_tea:
