I’ve been using Logseq for quite a while and absolutely love it. The only thing that I don’t particularly love is the way assets are managed. Been reading around the forum different opinions about it and ultimately IMHO having a single folder is probably better so that I don’t have to think about organizing anything and just let Logseq do it for me.
However… Sometimes I want to grab one of those assets and share it via e-mail or instant messaging app. How do you guys handle this? Looking thru all of my files gets tiresome to be honest.
I navigate to the page where I originally placed/ linked the image, than hovering the mouse cursor over the image , clicking on the path [Show image in folder] or use the copy icon [Copy image].
To make this work the image has to be displayed on the page
Yes, the path has to be adjusted manually and it works with sync, too.
This works really well for images! I never noticed that when I click on the Path it actually opens a file browser with the file already selected.
Doesn’t work with PDF’s tho. Nor other types of files… Just tried it out with a .3mf and a .doc file and both just tried to use the default program to open the files. It’s a very logical behavior, but makes it a bit more difficult to actually try to share the file itself.
In my case this is working on Linux (Open SUSE tumbleweed)
running the Logseq v 0.10.8 Appimage,
- [open PDF in its default application](../assets/doc_logseq.pdf)
- open PDF in ist default application
open PDF inside of logseq]]
The latter is also working in iOS 17.4.1 but will only offer a dialog to share or open.
File Options
Select an option to performe
Open
Share
Cancel
Yep, removing the ! does allow me to open files in the system default app.
However that’s not really what I was looking for…
What I ended up doing was rather simple:
- In Logseq click on the line where my file is linked and copy the file’s name
- Open my assets folder in a File Explorer
- Search for the file by name
- Profit
Feels a bit like a compromise and not ideal for me, but it gets the job done.
Thank yon @westenfalke for all your help and insight!
You might consider a plug (like logseq-plugin-open-in-external-app) to open images and pdf files in an external app. I did this in VS CODE a week ago to open markdown files in Typora, but I have to admit that the configuration was a bit fiddly.
