Jomi
January 22, 2023, 10:51pm
1
When using an outliner as Logseq, the bullets are very useful. An improvement would be to show the top level header without a bullet.
Can this be done in CSS or by marking the header as a title? I know you can switch to the document view without bullets but that is not what I want.
With bullet less headers, I think it looks much better.
Jomi
January 25, 2023, 1:38pm
2
I found a solution myself, make a change to the CSS:
div[level=“1”] > div > div > a .bullet-container .bullet {
background-color: transparent !important;
If you have even better solutions, please let me know.
danzu
January 25, 2023, 2:05pm
3
How does it look? Can you share a screenshot?
Jomi
January 25, 2023, 2:42pm
4
The big advantage is that you can add actions under the header, which are not a sub of the header. When e.g. showing actions in an overview, it will not show the parent topic as there is none.
