Currently, when you want to export the writings in logseq, you can simply use the “Copy As” function to export pure markdown text without all the [[]] and indentations, however, if there are tags present at the end of the selected blocks, they would still be exported along with the text. In most cases, the #tags are not needed in the exported text, which means users would have to manually remove them.
For example, in the screenshot below, I have #金句 at the end of the block, which serves as the function of archiving and sorting the quote, but I don’t really want it to show up in the final exported form.
It would be great to add an option to remove the #tags when using “Copy As…”.
