This is:
- an imperfect workaround for Better (human-readable) asset name
- inspired from File management from within Logseq, proof-of-concept, but fully independent from it
- In contrast to the above, this one is secure, as it exposes only
assetsfolders.
Usage
- At the end of file
preload.js, normally inside...\Logseq\app-0.9.13\resources\app\js, add these lines:contextBridge.exposeInMainWorld('renameasset', (path, oldName, newName, cb)=>{ const assetsPath = path + "/assets/" fs.rename(assetsPath + oldName, assetsPath + newName, cb) })- This gets affected by updates.
- Add a macro inside file
config.edn, insidemacros{}:
:rename-asset "<div class='kit' data-kit='renameasset' data-new-name='$1' />"
- This code requires having kits inside file
custom.js - Inside page
RenameAssetin Logseq, put the following code in a javascript code-block:
const LS = logseq.api
const Msg = logseq.Module.Msg
const rename = window.renameasset
if (!rename) return Msg.error("missing renameasset")
logseq.kits.setStatic(function renameasset(div){
const blockId = div.closest(".ls-block").getAttribute("blockid")
const block = LS.get_block(blockId)
const parent = LS.get_block(block.parent.id)
const content = parent.content
const index = content.lastIndexOf("/")
const oldName = content.slice(index + 1, content.indexOf(")"))
const newName = (div.dataset.newName !== "$1") ? div.dataset.newName
: oldName.slice(0, oldName.indexOf("_")) + oldName.slice(oldName.lastIndexOf("."))
const newContent = content.slice(0, index + 1) + newName + ")"
const path = LS.get_current_graph().path
rename(path, oldName, newName, (err)=>{
if (err) return Msg.error(err.message)
LS.update_block(parent.uuid, newContent)
LS.remove_block(block.uuid)
Msg.success("done")
- Under any (*) embedded asset (looks like
) add a temporary child-block:- Put the following content:
- If it is auto-named, to fix its name:
{{rename-asset}}- To use a different name:
{{rename-asset somename.ext}} - This should:
- rename the file
- doesn’t check for same-named file
- rename the link
- delete the temporary block
- rename the file
- (*) The parsing is simplistic, so any extra content in the asset’s block may interfere.
