Rename Page Shortcut plugin
I created a really minimal plugin that only registers a shortcut (default: mod+shift+t) to click the page title of the current page.
My use-case is that I often need to copy page names for cross-graph linking and I prefer keyboard navigation. To my knowledge, it is not possible to copy the page title using the keyboard alone without this plugin. With this plugin, I do Ctrl+Shift+t, Ctrl-a, Ctrl+c, Esc to put the page on the clipboard (on Windows).
Nice. For your particular use-case, could register a shortcut that uses Logseq’s API to directly copy the current page’s name, saving you from pressing Ctrl-a, Ctrl+c, Esc
Thank you! The plugin is now available on the marketplace as well.
