Since the result of queries has already support table view. I could use this feature to create more powerful table than using the raw markdown table. For example, I would create a page [[test]]
and then query this page at journals, and then change it to table view.
I think it would be more convenience if we could just create sub-blocks such as
and then convert the parent block into table view directly.
The disadvantages of the workaround are:
- I have to create a new page for each table (blocks work too, but query page is more easy)
- The backlinks could only reference to the row block rather than the whole table
btw, I am new to logseq, if there is better workaround, please let me know.
