I have a query which gets all blocks with the tag #priorityA.
Now I want to reorder the blocks inside the results of the query:
I want to move the important blocks to the top with the shortcut Alt + Shift + Up and the less important blocks down with Alt + Shift + Down.
Sadly, moving blocks vertically is currently not possible inside search results.
One way to implement this:
Given a page with:
- block one
- block two #priorityA
- block three
- block four #priorityA
The query result would be:
When having the cursor in block four of the query results and pressing Alt + Shift + Up, the original page shall be altered to:
- block one
- block three
So block four is cut and inserted again above block two.
Technically, the same code could be called like when the user does drag’n’drop.
