Searching for blocks, that are living in Whiteboard
Hi Logseq team,
When working with blocks within a page and then using search (command K), it will bring you nicely to the block, that you searched for, but when working with blocks that are living in a whiteboard and then using search (command K), it does not bring you to the block. It rather gets stuck on the whiteboard level, where the block is, but you then have to dig further to reach the searched block.
I hope searching in the second instance will behave like in the first one
Thanks
Stephan
