Self-hosted Logseq (with Docker) and plugins/storage
I’m in the process of trying different note-taking applications and so far Logseq seems to tick the most boxes (Markdown, open source, web client, plugins, native apps and modern Roam-like stuff).
I quickly spun up the Docker container, as I prefer to self-host, if possible. Worked out of the box, with the exceptions of developer mode and thus plugins. Would it be possible to enable plugins for the self-hosted solution? Also, are there any plans to enable the use of local server storage for the logseq files?
Thank you!
Are you planning to share your container on a place like docker-hub?
I just used the official one (logseq/docker-web-app-guide.md at master · logseq/logseq · GitHub).
Thanks! I didn’t know there was an official image!
its doesn’t work with any browsers
unlike the one hosted at logseq.com
