Hello together,
I am self hosting Zotero using uniuu/zotprime and I would like to use it with the integration in logseq. For that I would need to redirect my traffic to my local instance. I noticed in the zotero/api.cljs a base path for api zotero org. But when monitoring my traffic I noticed that it calls random amazon instances. Maybe my redirect from the api zotero org didn’t work correctly but what I was wondering is:
- Is it possible to change the base url?
- And is logseq using any other apis then api zotero org to integrate it?
Thanks for taking your time to answer this rather technical question!
Best regards,
Jason
