Howdy! I am putting this in Questions and Help rather than as a bug report because I suspect the issue arises from my own incompetence. I am using Obsidian to sync my graph across devices and have found that my settings, plugins, and theme are not syncing across devices. My favorites and my hotkey settings, for example, do not sync. Any advice on how to fix this would be greatly appreciated, thank you!
Obsidian syncs your graph and the graph config, but the settings you mention are stored in logseq config, not the graph’s…
In Linux, you can find logseq config at .config/Logseq/
. Don’t sync the whole folder!! It also stores ddbb and cache. I don’t know which of these files you should think, but maybe exploring a bit you’ll be able to find something.
