It looks like Logseq is missing a strikethrough short cut (at least on the MacOS) Can you please add it? Similar how we have now highlight shortcut
When you complete a task the task is shown with strikethrough … so it is possible.
Try :
~~text to be strikethrough~~
Although a shortcut might be handy.
Yes, this option is known, but pressing tilde sign for 4 times is not the same as having a shortcut to strike through selected text
In Windows it’s Ctrl Shift S. Don’t use Mac so no idea.
Thanks! It works similar on Mac: Cmd + Shift + S It means, that is just not in the shortcuts settings
