I was wondering (not super tech savvy here) if anyone knew how to prevent these the shortcuts from covering the UI for windows, windows management? See image screencap below. I do have several extensions installed - so this could be affecting the normal behavior of the application. I wanted to see if this was something common or specific to me. Thank you!
Found a solution for now: Using W11E and 0.9.10, I had to turn on the native title bar option to ‘ON’ which moved the Window’s UI buttons to their own area.
But I would love to see an option to change the extensions pins to the left or middle as well as their current default right. Thank you!
