Hi,
I’d like to make a query that shows all blocks that reference pages that match a wildcard */improvements
The idea is that I have several projects and open source programs that I use and I store ideas and stuff in the */improvements
subpage. I’d like to be able to view all the blocks that reference them
I have a query here that shows all pages using wild cards, but I’m not sure how to combine it with the page-links query to show all blocks that reference the matching pages. Here’s what I have that shows the pages themselves.
:title [:b "Improvements pages"]
[?block :block/name ?pagename]
[(clojure.string/ends-with? ?pagename "/improvements")]
Here’s my current attempt but it’s not working and I obviously not doing it.
:title [:b "select blocks with links to pages"]
[?block :block/content ?blockcontent]
[?block :block/page ?page]
[?page :block/name ?pagename]
[?block :block/path-refs [:block/name ?pagename]
Statement order matters.
We know which pages we want, so let’s start there. This also helps with performance.
Do we want blocks that reference this page, or do we want blocks that are on this page?
Right now your query has both true at the same time.
You state you want blocks that reference this page.
Following this, here’s the query.
{:title [:b "select blocks with links to pages"]
[?block :block/path-refs ?page]
Thanks for the reply! The good news is that this is selecting the correct pages, but it isn’t actually selecting any of the blocks where I’m referencing these pages.
What I do is in my daily notes, I have a section for random quick notes. If I have an idea for an extension or something, I use [[Program Name/Improvement]], and on the next line, I add my idea. This query seems to be display like, an embed of the page, but none of the page-links to the page.
Here’s my page for omnivore improvements:
Here’s what the query is returning:
My original try was copying this query and seeing if I could modify it to use a wildcard for */improvements:
( or
[?block :block/path-refs [:block/name "gardening"]]
[?block :block/path-refs [:block/name "vegetables"]]
Ohhhhh!!! Haha!!!
Took me a minute there. It’s because you are using the alias and not the pagename in the query!
Your pagename is */improvement
and not */improvements
So the query does exactly what you intend. It finds a block that references */improvements
as where you define the alias is a block that references a page named */improvements
Remove the s
from the query I originally posted.
You will see the alias as in its path-refs
is the page, because it is on the page.
You can either filter out blocks on the page. Or change path-refs
to refs
if you only require blocks that directly reference the page and not where a parent block references it.
To exclude the page:
(not [?block :block/page ?page])
Amazing, thank you! This works perfectly. I’ll share my results below:
{:title [:b "All blocks related to improvements"]
[(clojure.string/ends-with? ?pagename "/improvement")]
[?block :block/refs ?page]
To retool for your own purposes you can do the following: The purpose of this is to grab all blocks that reference a subpage in a hierarchy, for example it could grab all references to the [[Work/To Do]] and [[School/To Do]] pages:
{:title [:b "All blocks related to *"]
[(clojure.string/ends-with? ?pagename "/<subpage_name>")]
For this query, just replace “<subpage_name>” with the name of the subpage you’d like to query.
I am using refs instead of page-refs because page-refs was also including aliases, which was adding uncessary bloat to the page.
Thanks again!
