[SOLVED] H2 heading color light & dark theme
I want to change the color of the H2 heading, so I did tried this:
.editor-inner .h2.uniline-block, .ls-block h2 {
  color: black;
and that works for both the light theme (like I want) and the dark theme (like I don’t want.
So, I tried this:
.light-theme .editor-inner .h2.uniline-block, .ls-block h2, html[data-theme=light] {
  color: black !important;
.dark-theme .editor-inner .h2.uniline-block .ls-block h2, html[data-theme=dark] {
  color: #fce69f !important;
but that does not work for the dark theme. I thought it was a question of commas … again (:grinning:), so I played with them in terms of presence or deletion and placement, to no avail.
What am I doing wrong?
Testing this, we can actually get away with just this:
.light-theme .ls-block h2 {
 color: black;
.dark-theme .ls-block h2 {
 color: #fce69f;
Most importantly, we have to make sure we specify it is the .ls-block within .light-theme or .dark-theme and then whatever header we want (in this case h2).
To get that, we don’t add any comma’s.
Many thanks for helping me with that, I was hoping you would! :+1:
Your solution works, as usual, but there is something I still don’t understand.
To set e.g. the heading size at the same level for both light and dark, I have this:
.editor-inner .h3.uniline-block, .ls-block h3 {
  font-size: 25px;
I inherited the code and it works fine. That is where I got the editor-inner and .h3.uniline-block bits from. It even works for color, which will also be the same for light and dark. Why then, do editor-inner and .h3.uniline-block have to be left out if I want to differentiate light and dark?
They probably aren’t needed in those code bits either :yum:
So it is the reverse question actually. Why do you need them for that code? Would the code still work without it?
Yep, you are right, that code is not needed. That settles that question.
Sometimes/oftentimes, the simple solution is the best one, as per the KISS (keep it simple, stupid) principle.
Thank you for your probing question.
