Hi all,
I need to sort the result of my advance query per created time in descending order.
Any help?
In general, I would like to have more info on how to structure in the advanced query the sorting.
Thanks in advance
Hi all,
Any help?
Thanks in advance
For sorting we use the clojure function sort-by in the result-transform clause.
See here for details on the sort-by function:
https://clojuredocs.org/clojure.core/sort-by
Then for the query it will be like this:
(sort-by
(fn [d] (get d :block/created-at)) ; this is the keyfn from the docs
result ; this is the coll from the docs
Within the get we can select any attribute the query gives us.
We can add a > before result to reverse the sort order.
Hope this helps!
Thanks I’ll try.
One question if I want to sort the results by alphabetical order, can I use get block/name?
Or there is a better way?
Yes definitely! As a bonus it will sort case insensitive. If you want a case sensitive sort you can use block/original-name
It seems not working for me
the code is
{:title
[:h4 {:class "font-bold px-1" :style {:color "#2b2b2a":background-color "#9eb8f0"}}
"📓 Today's Journal"]
:in $ ?page
[?r :block/name "journal"]
[?b :block/refs ?r]
[?p :block/name ?page]
[?b :block/page ?p]]
:inputs [:current-page]
:table-view? false
(sort-by
> result))
:breadcrumb-show? false
:collapsed? true}
I add the > and it should show in the reverse order, correct?
What did I do wrong?
thanks
Also with the original-name seems not to work ![]()
the code being
{:title
:in $ ?page
[?b :block/refs ?r]
:table-view? false
(sort-by
(fn [d] (get d :block/original-name))
result))
:breadcrumb-show? false}
I must do something wrong
Thanks
You’re getting blocks with your query. block/name and block/original-name are for pages.
block/created-at is only available for blocks if the feature is turned on in config.
For sorting by the content of the block you can use block/content.
Your query code is fine as far as I can tell.
Set this to true in the config file: :feature/enable-block-timestamps? false
Hi all.
Any idea how to have a double sorting?
I have a query to search fro LATER and WAITING. I would like to sort first by marker and then by priority. Is it possible?
Thanks
Yes, double-sorting is possible. Some ways in Clojure: sort by multiple keys with different orderings
