Sort by multiple columns
I have the query below, which finds all open tasks scheduled for today, or with status NOW, and sorts them all by scheduled date ascending. How do I add to the query to put all tasks with priority A on the top of the list (sorted by scheduled date ascending), with all tasks with no priority beneath that (sorted by scheduled date ascending)?
{ :query [:find (pull ?b [*])
  :in $ ?today ?tomorrow
    [?b :block/marker ?m]
    (not [(contains? #{"DONE" "CANCELED"} ?m)])
    [(get-else $ ?b :block/scheduled ?tomorrow) ?d]
    (or
      [(= "NOW" ?m)]
      [(<= ?d ?today)])]
:inputs [:today :1d-after]
  (sort-by (fn [h]
    (get-in h [:block/scheduled])) result))
:breadcrumb-show? false}
Yes, for the love of god, can we please have some examples of this. Functional programmers drive me nuts sometimes, I miss my ORDER BYs.
@JPMoo @mpj please try this result-transform and let me know if it works
  ((->> coll (sort-by (fn [h] (get h :block/priority "Z"))) (sort-by :block/scheduled)) result))
Edit: Never mind, what I posted is not correct. I will post a better solution if I get it working.
Nope, that did nothing (I saw that you are editing so might have used a prior version).
It did, however, get me to try and see if the intuitive way worked:
{:title "📬 **All Open Tasks**"
         (task ?b #{"TODO" "DOING" "NOW" "LATER"})
  (sort-by (fn [h]
     (get h :block/created-at)
   ) result)
It of course didn’t, but then I thought about how insane hardcore functional programmers are and reversed the parameters, and it worked:
  (sort-by (fn [h]
   ) result)
Can you explain what the ->> and coll thing is indented to do? I really love loqseq but datomic must be trying to win some kind of championship in worst documented thing of all time. The search on datomic.com fills me with rage, how can someone manifest something this obtuse?
Indeed what I posted is not correct, I was following this comment where sort-by is composed like this
(->> coll
     (sort-by :first-name)
     (sort-by :last-name)
     (sort-by :age >))
I also tried this
  (->> result (sort-by (fn [h] (get h :block/priority "Z"))) (sort-by :block/scheduled)))
but it didn’t work.
I don’t think that the sort-by in this case is the clojure sort-by, which has a composable signature. If it was, my solution above would not work. I think that the sort-by here being called here is from the Logseq DSL, maybe this stuff, not well versed enough in Clojure to understand.
These technologies are promising is many ways and there are things that appeal to me philosophically but the tooling and docs around all of this is absolutely awful.
@mpj @JPMoo Now I got a solution that actually works:
  (sort-by (juxt (fn [h] (get h :block/priority "Z")) (fn [i] (get i :block/scheduled))) result))
I got this from an answer in the discord channel.
It definitely works this time.
Excellent, thanks for sharing.
I finally got my deadline drive task resurfacing work the way I want it, order by deadline first, then for the same day, order by priority.
Sharing my default queries here.
:default-queries
 {:journals [
   {:title "🔨 DAILY"
    :query [:find (pull ?h [*])
            [?h :block/marker ?marker]
            [(contains? #{"NOW" "DOING", "TODO"} ?marker)]
            [?t :block/name "daily"]
            [?h :block/refs ?t]
            [?h :block/page ?p]
            [?p :block/journal? true]
    :inputs []
    :result-transform (fn [result] (sort-by (fn [h] (get h :block/deadline)) result))
    :collapsed? false}
   {:title "🔨 NOW"
            [(contains? #{"NOW" "DOING"} ?marker)]
            (not [?t :block/name "daily"]
            [?h :block/refs ?t])
            [?h :block/page ?p]
    :inputs []
    ;:result-transform (fn [result] (sort-by (fn [h] (get h :block/deadline)) result))
     (sort-by (juxt (fn [h] (get h :block/deadline)) (fn [i] (get i :block/priority "Z"))) result))
    :collapsed? false}
   {:title "📅 NEXT"
            :in $ ?next
            [(contains? #{"LATER" "TODO"} ?marker)]
            [?h :block/page ?p]
            [?h :block/deadline ?d]
            [(< ?d ?next)]
    :inputs [:7d-after]
    :collapsed? false}
   {:title "📅 WAITING"
            :in $ ?next
            [(contains? #{"WAITING"} ?marker)]
            [?h :block/page ?p]
            [(< ?d ?next)]
    :inputs [:7d-after]
    :collapsed? true}
   {:title "📅 BACKLOG"
            :in $ ?next
            [?h :block/page ?p]
            [(>= ?d ?next)]
    :inputs [:7d-after]
    :collapsed? true}
   {:title "📅 WITHOUT DEADLINE"
            [(contains? #{"TODO" "LATER" "DOING" "NOW" "WAITING"} ?marker)]
            (not [?h :block/deadline _])
            [?h :block/page ?p]
            (not [?t :block/name "kaizen"]
    :inputs []
    :result-transform (fn [result] (sort-by (fn [h] (get h :block/id "Z")) result))
    :collapsed? true}
Rather than using juxt and having to pass in multiple functions to get a vector of the results back, you could just use a single function that returns a vector directly:
(sort-by (fn [r] [(get r :block/deadline) (get r :block/priority "Z")]) result)
Hey there, I tried using your query to get my tasks filtered by deadline, then by scheduled date and finaly by priority. My understanding is that the tasks with the same deadline are then sorted by scheduled, and if the scheduled date is the same, it’ll be by priority and so on.
Here is my query :
{:title [:h3 "🔨 Now"]
    [?b :block/marker ?marker]
    [(contains? #{"DOING" "NOW"} ?marker)]  ; Check if the marker is either "DOING" or "NOW"
:table-view? false
:breadcrumb-show? false  ; Don't show the parent blocks in the result
  (sort-by
    (fn [r]
        (get-in r [:block/deadline] "9999-12-31")
        (get-in r [:block/scheduled] "9999-12-31")
        (get-in r [:block/priority] "Z")
    ) result)) ; Sort the result by the deadline date, then scheduled date and then by priority
What I don’t get is why are my scheduled task not sorted correctly ? The second and third task don’t have any deadline, hence they should be sorted by scheduled date, but it is not the case.
If you have any idea what could be wrong there, I’d be glad to learn a thing today ! Thanks in advance !
Welcome.
  • I suspect that the query fails and thus uses some arbitrary order.
  • The provided fallback value "9999-12-31" looks suspicious.
    • It should be a number like 99991231 or 99999999
Thanks a lot, it was indeed the fix ! I did not think about it at all, even though it was stated here.
Here is the corrected script with multiple sort orders :
:table-view? false
  (sort-by
    (fn [r]
        (get-in r [:block/deadline] 99991231)
        (get-in r [:block/scheduled] 99991231)
For information, I managed to do combined sort (with asc, desc).
In my case below, achieving priority ASC + journal-day DESC, by reversing result (at first reverse priority alphabet, then last reserve once again.)
{:title "TODO (latest 30)"
 :query (todo TODO)
  (let [rev-pri (fn [p] (case p "A" "Z" "B" "Y" "C" "X" "Z" "B" "A"))]
   (->> result
    (sort-by (fn [r]
          (rev-pri (get r :block/priority "Z"))
          (get (get r :block/page) :block/journal-day 19000101)
    reverse
    (take 30)
    ;; ;; for debug dates (by returning :journal-day)
    ;; (map (fn [m] (update m :block/properties
    ;;   (fn [u]
    ;;      (assoc u
    ;;           :journal-day (get (get m :block/page) :block/journal-day)
In this case, journal-day is unsigned int, so you can use below as alternative:
(sort-by (fn [r]
      (- (get (get r :block/page) :block/journal-day 19000101))
;; without reverse
But I think this is special case which combined sort can be done with ease, so it’s ideal if there is multiplex sort function as default.
I also posted feature request of complicated sort funciton. I’ll write If any progress there.
