arrows
October 19, 2025, 9:21am
1
Hi all,
I am trying to sort the results of a query, but can’t get it to work for multiple properties.
This works for sorting on ‘topic’:
;Query 1
:query [:find ?p-name (pull ?b [*])
:keys topic b
[?details :block/properties ?details-props]
[(get ?details-props :topic) ?topic]
[(= ?topic "active")]
[?details :block/page ?page]
[?b :block/path-refs ?page]
[?page :block/name ?p-name]
[?b :block/marker ?marker]
[(contains? #{"TODO" "DOING"} ?marker)]]
:result-transform
(fn [result]
(map
(fn [r]
(update (:b r) :block/properties
(fn [p]
(-> p
(assoc "topic" (:topic r))
(assoc "deadline" (:block/deadline (:b r)))
(assoc "scheduled" (:block/scheduled (:b r)))
(assoc "priority" (:block/priority (:b r)))
(sort-by :topic result)
How to sort on priority and deadline as well?
Tried to move sorting to the top before trying multiple sorts, but it doesn’t work - what is the missing part?
;Query 2
:keys topic b
:result-transform
(fn [result]
(sort-by (fn [s] (get-in s [:block/properties :topic]))
(map
(fn [r]
(fn [p]
(-> p
result
Welcome. Check these threads:
arrows:
it doesn’t work
Please be more specific on what happens.
Some example blocks would also help.
arrows
October 19, 2025, 11:12am
3
Thanks for the hints! I tried the following:
This query orders nicely on topic:
:keys topic b
:result-transform
(fn [result]
(map
(fn [r]
(fn [p]
(-> p
like so:
I like to add priority and deadline:
:result-transform
(fn [result]
(map
(fn [r]
(fn [p]
(-> p
(sort-by (fn [s] (get-in s [:block/properties-text-values :deadline]))
(sort-by (fn [s] (get-in s [:block/properties-text-values :priority]))
Ordering is only on topic (like the screenshot above).
Tried moving sort, but this doesn’t show entries in the table:
:result-transform
(fn [result]
(sort-by
(juxt
:topic
(map
(fn [r]
(fn [p]
(-> p
result)
gives
Test data setup looks like this:
Page Logseq
Property topic with value active
Page Test topic
On journal 2025-10-17
#Logseq
TODO een tweede taak
TODO een vijfde taak
#Test topic
TODO #A een taak
TODO een derde taak
TODO een vierde taak
On journal 2025-10-18
#Logseq
arrows
October 19, 2025, 1:38pm
5
Thank you mentaloid.
Updated the parenthesis - those are hard to see!
Read up on the other post about missing/empty values and added that in the mix as well. I am overlooking something..
:result-transform
(fn [result]
(sort-by
(juxt
(fn [s] (if
(= "" (get-in s [:block/properties :topic] ""))
"Z"
(fn [s] (if
(= "" (get-in s [:block/properties :priority] ""))
"Z"
(get-in s [:block/properties :priority])
(fn [s] (if
(= "" (get-in s [:block/properties :deadline] ""))
"99991231"
(get-in s [:block/properties :deadline])
(map
(fn [r]
(fn [p]
(-> p
result)
Above shows:
This is the same as removing the whole sort - so it doesn’t seem to match the data and thus doesn’t sort.
arrows
October 19, 2025, 6:30pm
6
Found a way to view the raw data:
:view (fn [result] (for [r result] [:pre (pr-str r)]))
which shows:
There is a :block/properties with data such as topic set.
Why does this sort not work?
(sort-by
(juxt
(fn [s] (if
"Z"
(fn [s] (if
"Z"
(fn [s] (if
"99991231"
arrows
October 19, 2025, 9:12pm
7
Alright, found that the assoc in map used strings while the sort used keys, so fixed the assoc to used keys instead
It now starts sorting!
One thing to go is correctly sorting missing values:
why do the entries with no priority sort before A (and B), idea is that Z is used
why are no deadlines ordered before a deadline, idea is that 99991231 is used
arrows
October 19, 2025, 9:26pm
8
Alright, rewrote the if’s in the sort to or, somehow that does work. And used a number for the default date instead of a string.
All working!
arrows
October 21, 2025, 8:49pm
10
Good to know that an or is rewritten. It is much more compact, so I do like it more in this case.
This is the ‘final’ version. Meanwhile I tweaked it more for my specific needs and use it together with other queries to setup a system to organize my work.
Query sorting on:
topic, actually can’t be empty as the query looks for it,
priority, assumes no priority is a BB priority which sorts it after B but before C, and
deadline, no deadline means 9999-12-31.
{:title "TODO's related to active topics"
:keys topic b
[?topics :block/properties ?topics-props]
[(get ?topics-props :topic) ?topic]
[?topics :block/page ?page]
:result-transform
(fn [result]
(sort-by
(juxt
(fn [s] (or (get-in s [:block/properties :topic]) "Z"))
(fn [s] (or (get-in s [:block/properties :priority]) "BB"))
(fn [s] (or (get-in s [:block/properties :deadline]) 99991231))
(map
(fn [r]
(fn [p]
(-> p
(assoc :topic (:topic r))
(assoc :deadline (:block/deadline (:b r)))
(assoc :scheduled (:block/scheduled (:b r)))
(assoc :priority (:block/priority (:b r)))
result)
The query then shows:
