Based on the answers in this thread I’ve tried to add a sort to my “near future” query, so it sorts first on deadline, then scheduled.
(sort-by
(juxt (fn [r] (get r :block/deadline 99999999) ) (fn [r] (get r :block/scheduled 99999999) ) ) result
(->> result
(map (fn [r] (assoc r :block/properties {
"scheduled" (get r :block/scheduled)
"deadline" (get r :block/deadline)
"marker" (get r :block/marker)
Unfortunately, it just doesn’t seem to be doing anything. The sort is out of expected sequence
If I remove the mapping to include the extra fields in the results, the sorting works as expected, so that is fine. I’ve now put the sort logic in a number of places though, and either it doesn’t activate, or it produces an invalid query.
What is the correct :result-transform
setup to achieve this?
Looks like a wrong syntax (although I’m not familiar with ->>
). Should nest map
inside sort-by
, as if it was its result
input (otherwise sort-by
has no effect). Here is a recent question with a similar structure: Unite different :result-transform’s
I’m also not familiar with this syntax.
I never got it to work either.
I’m not actually sure where I got that ->>
from now - pretty sure it was a query from another issue on here. Anyway, that does work because the properties show in the table OK, it’s just the combo I was having problems with.
Thanks for the link to that other thread - I think it’s sorted now. I took out the ->>
part, though it works with or without it, which I find odd (i.e. it’s not a syntax error, but seems to make no difference … wish I could find the original suggestion I got that from now!)
So, for future reference, and to aid future seekers of knowledge, this is the final result-transform
, which does what I want
(sort-by
(juxt
(fn [r] (get r :block/deadline 99999999))
(fn [r] (get r :block/scheduled 99999999))
(map
) result)
