Hi!
I’ve just started exploring Logseq, after having used Roam Research for a while. I’m trying to figure out the best way I can set a block to repeat periodically, just like Roam’s delta function. I’m not a coder and I would like to figure out the swiftest way to be able to do this often since I use this function a lot.
What I would like to do is -
- Set a block to repeat after (for example) 2 days from 28 Feb.
- The block appears on the Journal page on 02 Mar.
- Choose if I want the block to repeat again after 02 Mar. (in Roam it’s done by clicking the delta symbol)
What I don’t want to do / am unable to do is -
- Turn it into a Flashcard
- Turn it into a TODO item
- If I try scheduling the block, any other block that I’ve already scheduled gets modified as well. Obviously, I don’t want that to happen. I would like to schedule each block on it’s own cycle.
I’d appreciated any inputs and ideas on this.
Thanks,
Pallavi
