Hi,
I’m trying to use Logseq on my PC and Mobile with syncthing and its works well except when occasionaly two of the same journal days are created and havent fully synced correctly.
I was wondering if there was a way to stop the auto creation of the journal day and instead if it was possible to have some kind of hotkey to create it as needed?
I saw in the settings that I can disable the journals completely which isnt what i want to do but instead I want to create them ‘manually’.
Thanks,
Mitchell
