Subscript and superscript
Is there a way to format text to subscript and superscript?
I work with academic papers with chemical formulas and would like to easily capture such information.
Logseq supports Latex, so you can do this:
#+BEGIN_EXPORT latex
a_1^2 + a_2^2 = a_3^2
#+END_EXPORT
You can type this in directly or type “<” to show the commands list.
I was wondering the same thing. Turns out it is possible like this: X_{sub}, X^{super}
This works perfectly, Thank you very much
