Sync issue? What is this?
For the last month I’ve been getting this non-stop when I open the app and can’t create [[links]] until I close the popup. Anyone have any ideas what it is and why it’s happening?
Edit: Running latest version of macOS and Logseq 0.10.9 (83)
I cannot tell for sure as I don’t recognise all of your plugins, but I would expect that it’s a plugin is trying to produce an error message.
You could try isolation which one by deactivating them one at a time (assuming that doing so won’t break anything else immediately).
Or first, just make sure your plugins are up to date.
That solved it. I haven’t checked my plugins for so long I forgot I had most of them turned on I use them so little, haha.
Thanks!
