This little interactive template embeds an entire article directly into a page.
instead of creating links as usual, create a link via this template, then when you press the button next to the link, the article gets embedded into your page as markdown!
BEFORE:
AND AFTER:
I haven’t tested this thoroughly, I just made it work and wanted to share
(requires an extra user-script, so won’t work in desktop app, for now)
for privacy sensitive people, you should know:
- the userscript uses 2 public libraries from a CDN
- it may inline some assets from the article (like remote images), which you may not necessarily like (I will make inlining images optional in a future update)
