In Logseq there are two ways to embed blocks:
- By embedding a block and its children
- By embedding an entire page with all of its blocks
Block embeds
The easiest way to embed a block is by calling the block embed shortcode using the trigger menu. Type /block embed
, press the Down key, and hit Enter to select the option in the trigger menu:
Now, you get the following shortcode:
Between the ((double parentheses))
, you place the address of the block you’d like to embed. Alternatively, you can start typing words here to search for a block.
Page embeds
Apart from (branches of) blocks, we can also embed entire pages. To do so, use the /page embed
trigger to call the page embed shortcode:
Inside the [[double brackets]]
, type the name of the page you wish to embed. Click outside the block and the page’s contents will show.
Not sure if you’ve embedded a block or a page? Page embeds always show the page name on top of the embed (in this example the page Parent A):
