When creating a TODO item, please consider a feature to automatically prefix the next block with a TODO
Maybe it’s enough for you to use the Rotate the TODO state of the current item
keyboard shortcut as soon hit ENTER?
I have the same request as @Deviation.
When I press Ctrl+Enter it cycles: LATER
> NOW
> DONE
. There is no TODO
option.
Check also option :preferred-workflow
in file config.edn
