shortcut to toggle between expanded and collapsed. This would reduce the usage of collapse/expand to just one shortcut instead of 2.
It might be the case that “toggle-open-blocks” is the command you are looking for, search for it here.
I tried to include it as a command in my config, but when I use my assigned keyboard shortcut, it doesn’t seem to work. Either I have misconfigured the command, the command doesn’t do what I presume it does, or there is a bug.
So - Dynalist handles this beautifully and this one shortcut is a large part of why I am not ready to move from Dynalist. They way they handle it is [Ctrl + Space]. It’s a one-handed action to toggle the expand/collapse of a node.
