im pretty new to Logseg; One Thing I couldnt find out or find a plugin for is a toggle for edit mode.
Current behavior is; I click inside a page and it immediatly change to edit mode. What is fine when writing notes this is sometimes annoing when I need to read through alot of pages and notes.
Is there any way or hotkey to make it a toggle? Like new default: If I click or drag in the text it will just highlight but not change to edit mode. Only when e.g. a hotkey or button is pressed I will edit that page?
To assign hotkey in Doc View Exporter plugin, go to menu -> settings -> plugins -> Doc View Exporter and change the defined shortcut as wished (default for me is set to mod+shift+d). You can also edit plugins config from the plugins window in installed plugins. Select the cog under the plugins then open settings.
Edit: I think I had to restart the app to make the shortcut work.
