Is there any way to eliminate the 2s delay between hovering and showing the preview tooltips? I find it really slow for my workflow.
Welcome. If you feel adventurous, follow these steps:
- find file
main.js- normally inside
...\Logseq\app-0.9.18\resources\app\js
- normally inside
- make a copy of it, just in case
- open it in a good editor
- search for string
delay:this.props.delay- this is duration in milliseconds
- its current value is 1000, i.e. 1 second
- replace it with something smaller
- e.g.
delay:100
- e.g.
- save the file
- reload Logseq
- the change will be lost on next update
sadly, there is no such file with Logseg v0.10.*
Actually, there is app.asar file. Unpack then repack it with “@electron/asar” allows modification of source js file
