UDS:DangerousObject.Multi.Generic?
Hey! I tried to download the app from the main website and my antivirus showed the presence of a “virus”. Windows accused Malware along with Kapersky. Does anyone know what can it be? Cited file: “UDS:DangerousObject.Multi.Generic”
same here. Posted a question on discord and waiting for an answer
No answer so far lol. Guess the antivirus software mistakes it for a malicious program and people just ignore it.
I thought about that possibility. I can disable my antivirus, but maybe later it can give some problem, because Windows also accused. Thanks a lot for the help! Let’s see if anyone shows up here to comment anything else.
If you want to proceed, as I did, add the files/folder of Logseq that the antivirus software detected to the exclusion list (so that it won’t scan the folder). Don’t disable your antivirus completely.
Excellent! I am going to try! Thank you!
Thank you for the reporting! The reason is that the logseq app (on Windows) is not signed yet.
We’ll fix it later.
thank you! Congratulations on the app!
