Hello.
I am new to Logseq.
I am using latest 0.9.1 version.
The problem is the following.
I’m trying to navigate to a specific block from the search results.
If I select a page, the page opens from the beginning.
If I select a block in the search results, then the behavior is undefined.
I found that if there is only text in the file, then navigation to the block occurs, but if there are pictures, then there can be two options:
- The block opens as a separate page when clicked in the search results
- Navigation to the block happens as it should.
I have not established the exact algorithm.
I made an example file on github.
Markdown file + picture.
The image should be placed in the assets folder.
You need to search for “Item 25”. The latest block.
If I do a search and click on the result for a block, that block opens as a separate page.
Is it possible to scroll the page to the block position?
For example, in RemNote, if you open a block and then click on the parent page, the parent page will open at the position of the block.
I am not a native English speaker.
Thanks in advance.
