Is there a way to remove/unregister a command from the logseq command palette? I don’t seem to see it on this page: IAppProxy | @logseq/libs
It’s a hidden command @dvargas92495
logseq.App.unregister_plugin_simple_command(`${logseq.baseInfo.id}/${key}`)
/Key is optional. So you can just have the base info but then it would un register all the commands in case that’s what you desire.
nice thank you! Any reason why it’s hidden and not documented? Also seems like it’s not in the typescript types
