Hi,
How should I change the custom css to make sure that the page area is adjusted to the whole width of the logseq window?
I think the following might be what you are after. Adjust 1000px to whatever width you would like
:root {
--ls-main-content-max-width: 1000px;
Before using the suggested CSS, did you try the wide mode?
The shortcut (works when you are not editing any block) is:
t w
it stands for Toogle Wide mode.
For some reason I couldnât make this work. Copied and pasted on the custom.css but nothing changed even if I adjusted the XXXXpx to other values.
Also is it possible to do 95% of current width of the window vs nominal values?
This is definitely helpful but would be great to have more granular control
Hi Nottakumasato,
Only thing I initially thought was maybe to look throughout your css file for another instance of : root {}
and place it within there with the rest of things. If you just copied and pasted you may have two : root
In terms of your relative width question, I believe that you could play with
--ls-main-content-max-width-wide: 100%;
however 100% is the default as per the Github repo so not sure how much luck you would have with making it wider than it ships by default.
Weird. I am using the default Logseq theme:
And my custom.css looks like:
However still canât get it to adjust the width. Anyways ât wâ is good enough for now
Awesome, do you want to flag @alex0âs comment as the solution then? May help others that stumble upon this to quickly find the answer that helped you best.
Try without the space between :
and root
:root {
It works for me. Also itâs convenient to edit the custom.css file with an external editor because the Logseq integrated one doesnât save invalid CSS without notice, making you think the CSS applied while it doesnât.
I guess there is another implicit limit to the width somewhere since when I do 10000px:
and open up logseq on my widescreen:
there are still areas not used.
Thanks for this pragmatic hint. Wasnât aware of it.
Is there a summary of âhelpful togglesâ somewhere?
Open the search bar, you will see a little icon on the top right (next to the toggle âsearch in pageâ). That will show all the shortcuts.
Super duper, alex0!!
You made my day - Wasnât aware of this
Thanks much
out of curiosity what is the default width of logseq in css , because I personally like it and would just like to make a note of it
