An optional warning that would warn the user prior to breaking a block reference by deletion of a block (or something else that may break the reference, like moving the block to another line).
It has happened to me that I’ve merged blocks together and accidentally broke existing references without noticing it. I think it would have been very useful if I had gotten a warning, otherwise, it becomes easy to break things.
this is a duplicate of Prompt user to confirm deleting block when an existing block reference is linked to the block @Bader
Thank you ![]()
Will close this feature request in favor of:
Do you have the permission to merge posts like Ed Nico did? It seems there’s a way that automatically merges votes and replies.
Edit: Oh nevermind, I just realized that this post has not been closed yet.
hmm I probably do I just don’t know how to do it. I’ll look into it. Thanks!
