Hi
Does anyone know if there is a web clipper planned for LoqSeq? I have started using it but I am missing this particular thing that I used to use a lot in Joplin. I think that Joplin’s clipper is one of the best among the open source note takers.
Hi
Hi. I’m not familiar with Joplin - but there is a Chrome add-in called “Roam Highlighter” that works well with Logseq. I’m not a tech guy - but you can get more details by searching that name in the Discord channel.
Hi
Those (I found two in the chrome store) look like you need to copy paste between the browser and LoqSeq. Joplin’s web clipper clips the page and creates the page in Joplin automatically without any copy and paste stuff, therefor I can for instance send the web page to another Joplin instance to be clipped.
I created open-source web clipper for obsidian that can easily work with logseq.
Extension name: markClipper.
markClipper need local folder permission to work.
If you’re familiar with obsidian then you need to know that vault is just a folder in local os file system.
Add your local folder in markClipper vault list and start using web clipper.
markclipper - chrome web store
Read more about markClipper at Github
markClipper
Now you can try Send to Logseq, a Web Clipper browser extension for logseq, it sends page content to Logseq directly via its HTTP API, not need to manually copy & paste, or import markdown files.
