Logseq uses Markdown syntax but not every Markdown file is a valid Logseq page, basically because of dashes: Logseq expects them to define blocks. This means Markdown files need to be converted to Logseq’s format and vice versa.
My question is: were dashes really needed? Couldn’t block be defined by new lines only? I mean “at least one empty new line” as a block delimiter:
This is the first block. Lorem ipsum dolor sit amet,
consectetur adipiscing elit, sed do eiusmod tempor
incididunt ut labore et dolore magna aliqua.
Ut enim ad minim veniam, quis nostrud exercitation
ullamco laboris nisi ut aliquip ex ea commodo consequat.
This is the second block. Duis aute irure dolor in
reprehenderit in voluptate velit esse cillum dolore eu
fugiat nulla pariatur. Excepteur sint occaecat cupidatat
non proident, sunt in culpa qui officia deserunt mollit anim
id est laborum.
This is a child block indented with a tab. Sed ut
perspiciatis unde omnis iste natus error sit voluptatem
accusantium doloremque laudantium, totam rem aperiam,
eaque ipsa quae ab illo inventore veritatis et quasi
architecto beatae vitae dicta sunt explicabo.
In my opinion if possible this would had been much better. So out of curiosity, is there a technical problem with this syntax?
