Hello!
I’m having a bit of a problem with using $$ $$.
A lot of the stuff I want to be doesn’t seems to be supported. Where can I find what is possible and not?
e.g. \parbox
$$ \parbox{10cm}{text} $$
Hello!
e.g. \parbox
Logseq (reportedly) uses KaTeX, so you should check which subclass of full LaTeX is implemented in KaTeX: Supported Functions · KaTeX.
