I am looking for config.edn
in order to customize the keyboard shortcuts of Logseq. I checked ~/.logseq
folder but I couldn’t find it there.
Hi @mertnuhoglu ,
it is in the folder where you defined your graph ~/logseq/config.edn
it is also editable in logseq …/setting/General - custom configuration
Thanks. I found it through Settings > General > Custom Configuration - Edit config.edn
Every different repository has a different config.edn
. I was assuming that there was one config.edn
for all repos.
