Use Case: Describe Why You Need Whiteboards and How You Use Them
Whiteboards are primarily used for two purposes:
- To help visualize and organize thoughts, usually used for complex problems;
- To visualize my thoughts on a complex problem, making it easy for me to review quickly or share it with others.
Most Wanted Features:
- The transformation of whiteboard views into a trello-like list: The whiteboard view can be transformed into a trello-like list (according to the relationship lines and hierarchy in the whiteboard). The resulting list can be messy if it is, and can be edited in the list view. Logseq will record the edits in the list view.
- Automatically showing bidirectional link relationships in the whiteboard view( reference to Lattics).
- After writing the article in hierarchical ways, you can export Word and MD at a single click. This is very convenient for writing.
##What other Whiteboard/Mindmap programs have you used before, describe their strengths or how they could be improved
Lattics
Strengths:
- The article can be split into hierarchical levels and the whiteboard view can be generated based on the hierarchy. The whiteboard view can be freely edited and the hierarchy relationship will be synced to the list view.
- The whiteboard view shows bidirectional link relationships, shown via dashed lines, which is very helpful for us to discover potential connections.
