I’ve noticed that when I create a [[topic]], there are duplicate entries under Linked references for that topic. Can this be changed to display only the single reference for the Journal day that it was entered? It’s quite confusing to see multiple linked entries for the same day. The duplicate pages show up as 2022_07_07(1), (2) etc…
Here is another example:
Would appreciate if anyone knows how to avoid this to ensure a single backlink to the day that the topic was created, many thanks!
First rule when using iCloud: don’t leave Logseq open on any device. Instead, close it when you’re done with it. This will make it less likely that iCloud creates duplicate files.
Thanks Ramses for the tip on using iCloud. Will definitely shut down Logseq on devices when not in use. I’m assuming this for IOS as well.
My need for syncing is on Windows, Mac and IOS.
Quick questions on the alternate sync options:
Does Syncthing work on IOS? At least in the video intro, he mentions it’s not supported.
Does Github have auto-sync capability or would I manually have to sync it every time?
I’m not very familiar with GitHub sync, and personally, I only sync manually for one collaborative graph that I use on one machine. Have a look at the article I linked to, or search the forum for “Github sync” as there seem to be a few discussions about it already: Search results for 'github sync' - Logseq
