Currently a long src block has to be scrolled:
This feature request would make it multiline representation, that fits to the screen, something like this:
Solution to change logseq custom css file (under Settings>General>Edit custom.css ) or under the folder logseq->custom.css
/* Wrap the content inside code blocks in all themes */
pre, code {
white-space : pre-wrap !important;
Hello, I notice a better solution today, similar topic via: Make it easy to configure syntax highlighting theme?
The logseq pull request is Feature: add codemirror options by andelf · Pull Request #3699 · logseq/logseq · GitHub
Adding those code to your config.edu in setting.
:editor/extra-codemirror-options
{ :lineWrapping true }
They have many other options, and that’s make more sense than custom css (such as pointer shown).
Is it possible to turn on word wrap only for a single block?
The problem with the CSS solution is that selection of text in code blocks then is buggy.
The:
config.eduin setting
Does not have this problem, apparently.
