I would like to browse my articles from the group library as well, but I don’t know how I can get the API key or group id that requires access to the group library from logseq.
Does anyone have an answer for this?
你想要的应该是 Group ID
登陆在线 zetero
进入 “Groups” 选项卡
点击目标 Group 名称
在浏览器地址栏,groups 后的数字就是 Group ID。
Translate via Google:
What you want should be the Group ID
login online zetero
Go to the “Groups” tab
Click on the target group name
In the browser address bar, the number after groups is the Group ID.
You rock! Thanks a lot!!!
