echej
September 2, 2021, 1:37pm
1
This is a small tweak - having a possibility to choose what the note created in Logseq will use as a name.
Currently, it is the title of the article.
I would like to customize it to add to it a citekey (citekey + title) or replace the title by citekey alone.
That’s already implemented if I understand your requirements correctly. There’s a setting “always prefer citekey as your page title” in the Zotero settings.
echej
September 4, 2021, 11:43pm
3
Thanks! This option doesn’t work if you doesn’t have pinned key
I found the solution through Roam version of this plugin
https://alix-lahuec.gitbook.io/zotero-roam/getting-started/prereqs
I also open a GitHub issue to improve documentation https://github.com/logseq/logseq/issues/2769
