Auto-Pair Toggle and Custom Map
Please allow disabling some (all?) of the pre-defined auto-pair and let us define custom ones in a text expander way, not only closing the opening characters but maybe [[ should expand to []([[]] ) if I need to.
See it here:
Any particular answer from there I should be aware of? I have commented myself on that thread a while ago, but I am not aware of any advancement on the subject …
Not aware of any, just mentioned just to join the voters.
I found a way to “Disable” some “auto-pair” combos by using Espanso text expander. Below is just an example for the one i fond most annoying:
- trigger: "`"
  replace: "`"
  label:   "Logseq Prevent Doubling the 'BackTick'..."
It also works wit others like “(” or “[”. Hope it helps…
I find that Logseq doesn’t double it anymore as long as Espanso does it’s replacement :face_with_raised_eyebrow: :grey_question: :grey_question:
I use Keyboard Maestro for this sort of thing.
Triggered by any of the following (only for Logseq application)
  • The exact case string “[[” is typed (no deletes)
Will execute the following actions:
  • Type the Forward Delete Keystroke
Sadly this doesn’t work for me (MacOS 15.5, logseq 0.10.12).
I got espanso and using the same match as you, but the second backtick is still being expanded by logseq :confused: Well, hopefully this will get picked up and supported natively by LogSeq.
I don’t think anybody would mind if the auto-pair feature was removed completely for back ticks.
