Blocks reordering themselves whilst typing
Hello folks,
A common part of my workflow will be working on the “Linked References” list on a given page. I will often work on blocks directly within this list, e.g., changing tags, marking things as a task, changing task state, etc.
However, whenever I change a tag or do anything with tasks, it seems to re-order the blocks arbitrarily, and I get bamboozled and lose the block I was working on. For example, I’m on Page X, and the “Linked References” section shows that Page X is mentioned in 10 blocks on Page Y. I start working on these 10 blocks listed under “Page Y”. If I change a tag or task status on this block, the order of the list will immediately change, completely arbitrarily (at least I can’t see a pattern).
I’d rather thees 10 blocks stayed in the same order so I can work through them one by one. Is there a way to make these lists less jittery and stay still? Maybe there’s a less frustrating way to do what I’m doing?
Hugely appreciate any help,
Thanks!
Welcome!
There is no best solution. See Editing Linked Reference blocks causes disruptive page refresh and reordering for a similar thread with a suggested workaround.
It would be nice if we could reorder the list of linked references (drag and drop?)
