Changing font and font size in the quoted code blocks
What is the current way to set the monospace font and font size (I want to use First Code with ligatures enabled, and 12pt size), only for the “code” in quotes? I could not find any working example of this.
Related question: I believe the “custom.css” configuration is applied when one uses the default dark/light themes, but it does not seem to apply when using a theme from the marketplace. I am using one of the variants of Nord Flow - Is there a way to customize it by editing custom.css or do I need to find the source of the theme and modify the theme directly?
Thanks @mentaloid! - I will try this out today. I am using logseq on linux - flatpak.
I believe the flatpak does not have access permissions to the system fonts, in my tests I installed the Hack and Fira fonts (via deb packages) and it seemed that Logseq was not able to use them.
Do you need an @import line for logseq to be able to use the fonts? if yes, do you know how do you specify that the fonts are local? I saw some imports pointing to files on CDN, none of the examples seemed to use the locally installed fonts for some reason
For local @import options, read Custom.css can’t import?
Thanks @y_p , super helpful, it worked. In the flatpak version, the Fira font setting only seems to work if Include the import statement (importing the font from a URL), regardless of it being locally installed
Question: how can I separately target with a font color change the text within single quotes (not the code-blocks that are within triple quotes, but the single-quoted single-line blocks e.g: example of regular quoted block. Which html selector should I use to have:
color: #aaa;
To only apply to the text within single quotes?
This is because in my theme (Bonofix) the text within single quotes is rendered in red.
after a bit of tinkering, I learned that
  • logseq flatpak is able to load any font installed locally, no need to @import it
  • some themes do not support ligatures even if you are using a font that supports ligatures like Inter, for example the theme I was trying to use (Flow Nord - One dark); however as mentioned above, you can tweak custom.css to make the theme enable ligatures
The below custom.css config allowed me to tweak CodeMirror blocks, regular Code blocks, sets the main/regular font, and enables ligatures for Flow Nord that didn’t support that out of the box.
/*@import url('https://fonts.googleapis.com/css2?family=Inter&display=swap');
@import url("https://fonts.googleapis.com/css2?family=Fira+Code&display=swap"); */
:root {
  --ls-font-family: "Inter", sans-serif !important;
  --ml-feature-settings: "ss01" 1, "ss02" 1, "ss03" 1, "ss06" 1, "ss10" 1,
    "ss11" 1, "zero", "onum", "liga" 1, "calt" 1;
  --ls-font-feature-settings: var(--ml-feature-settings);
  --cl-font-family: var(--ls-font-family);
html, body {
  /* some themes like Flow Nord do not properly set font-feature-settings,
     hence ligatures do not work out of the box, the below fixes that (linux) */
  font-variant-ligatures: normal !important;
  font-feature-settings: var(--ls-font-feature-settings);
/* code-mirror blocks */
.CodeMirror pre.CodeMirror-line
/* , .CodeMirror-linenumber, .CodeMirror-scroll,
.CodeMirror-sizer,
.CodeMirror-gutter,
.CodeMirror-gutters, */
  font-family: "Fira Code", monospace !important;
  font-size: 14.5px;
/* single line blocks */
code {
    font-size: 14.5px !important;
    /* ligatures are not supported in any known theme inside single quotes */
    color: #aaa !important;
