I often want to quickly open a page. ctrl+k searches all blocks and also prompts me to create a new page, or a new whiteboard, as the first item for partial matches (see picture), which means I have to enter two keystrokes to get to the page I want. I only want to search page titles and I don’t want to create a new page for a partial match. It would be great if logseq could support this open page shortcut with ctrl+o.
there is a simple solution - just have the ‘go to page’ appear above the ‘create new page’ using command K. this is similar to the behavior if you type [[ - it defaults first to search, then you can down arrow to create new page or whiteboard. no need to create a different short cut IMO so we can use command K to quickly go to a page and keep the same muscle memory. like spotlight in safari or most other tools
