is there a way to customize a shortcut that I can press so that Logseq inserts a custom character sequence into the document at the current cursor position?
For instance, I’d love to be able to press Ctrl + Alt + P to insert this sequence:
" → " (8 spaces, arrow to the right, space)
In config.edm there is a section to add custom slash commands. I’ve not been able to get a shortcut to do that.
:commands
["arw", "- ==> "]
The section in config.edm to add shortcuts only calls logseq Clojure functions I think.
The problem here is the leading spaces get truncated to one space so you need a leading alphanumeric (- shown above).
You could use AutoHotKey to expand a shortcut into a text string but it’s a lot to learn for a simple expansion.
Or Quick Access Popup is a free windows app that can do this.
