I recognized your usecase as legitimate since my first reply in this thread.
I tried to help you in multiple ways and I just shared my workflow where this issue is not prominent.
Logseq doesn’t support your use case with Simple Queries but it would be nice if it did. This has been my position for the whole thread.
Logseq supports your use case with Advanced Queries. I can’t find your request for help on Discord#queries as I just suggested to do.
I understood your point from the beginning and we discussed it for a while, no need to reply in a prickly way like I didn’t understand the issue at all.
You hit the second strike of being mannerless (first one here).
You even refused to rename this thread despite I said many times “unify” is the wrong term in a polite way.
Again: Not any intention to be rude from my side. I am sorry, if you perceived the discussion in a different way.
Sorry, but simply no. Read again before and after the post, as well the comments from others users.
By chance: Have you overread that I intent to close this post? After discussion, my expression was this post is either
a) too broad for a specific feature request
b) rather a bug report.
(still not sure about this)
The whole post has been about making page and block behave like one common unit, so just renaming the title would confuse future readers more than help.
But the main issue discussed here as not been addressed yet i.e. now in DB version we have a menu entry named “Node reference” that let the user pick a page or a block and it appears as a [[wikilink]] using the title of a page or the content of a block. But when you manually type the same wikilink somewhere else it creates the classic page.
So we have wikilinks that looks exactly the same but point to different things:
The blocks could have an optional name: property set manually by the user or automatically (more later)
[[name]] could display the unique name given to the block
![[name]] could display the content of the block when used inline with other text…
…and embed the whole block with children when used on its own line
For example:
- content of the block
Name: short unique name
- child block
- This is a reference to [[short unique name]]
- This is an inline embed of ![[short unique name]]
- ![[short unique name]]
Rendered as:
- This is a reference to short unique name
- This is an inline embed of content of the block
- child block
The same would happen with pages and their titles.
“Short unique name” could be set manually by the user or by a ML algorithm (for faster workflows when using the current Node reference menu selecting blocks with no name) and it doesn’t matter the format as long as it’s unique. For example the algorithm could use parent and children blocks to infer that a proper name could be The Title (book) and assign it if there isn’t another block with that name. The user could change that later.
